Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD24T tight plunger shearing bolt
showcrop
04-30-2013 04:33:03
2X what Rod says. I had a 336 that despite the PO telling me that he always shedded it had bad rust. The rust in the bottom of the chamber pushes up the rails that that the plunger head rides on. Yo will need to remove the plunger head, which is not a big deal except for the rust, so you may need to chain it to a tree and the pull the baler ahead. I cleaned mine good then painted with rust inhibiting primer. Two years ago someone came on here with that problem and tried different things for three weeks to get the rails out without removing the plunger and then finally gave in and did it. While you are at it clean and paint under the knottters and put new springs in the hay dogs.
