TractorLinks.com
492 New Holland Haybine lowering
Charllie in MO
04-29-2013 18:40:08
I bought a New Holland haybine, 492 if I remember right. We went to use it and raise it up to undo the t-arm that holds the weight off the cylinder when transporting and can't get it to raise. There must be another latch or something holding it, maybe on the right side? Please help, we are getting ready to silo some rye and are in a bind.
Thank you,
Charlie....not mechanically inclined
Bret4207
04-30-2013 04:44:03
 Re: 492 New Holland Haybine lowering in reply to Charllie in MO, 04-29-2013 18:40:08
There's nothing on the other side to lock it up.
charlie n
04-29-2013 20:19:56
If all else fails switch the hoses.Could have the up plugged in the down.
JMS/.MN
04-29-2013 19:23:04
You might have air in the cyl......remove it and cycle it several times to get full stroke at its normal speed.
Brendon Warren
04-29-2013 18:52:08
If its like a 488 or479 it should be the only thing holding it up maybe something is up with your hydralics. Just a thought.
TractormanNC
04-29-2013 18:47:55
Your tractor may not have enough hydraulic pressure to raise the header off the stops. Also the spool valve in the tractor may be leaking down before you can jump off the tractor and release the transport lock. Don"t ask me how I know about both of these troubles.
T in NE
05-05-2013 10:14:37
 Re: 492 New Holland Haybine lowering in reply to TractormanNC, 04-29-2013 18:47:55
The 492 replaced the 489 after they got bought out.
