Deere Scotty
Anybody know if there is a place to get a suction blade for a late model 709? Mine needs a flat suction blade. JD only carries offset blades. If I put an offset blade on mine; the blade will be below the skid plates. Somewhere down the line they changed the blade holder from straight, to about a 3 inch drop to protect the center bolt; but never made a suction blade to counter the offset. (dealer claims).
If no blade available; then can I change the blade holder to the old style without changing the bolt on the gearbox? Instead of changing blades to go from heavy brush to grass I could just change the bar & leave the blades on it!
