TractorLinks.com
Re: JD WHEEL RAKE
Tx Jim
04-28-2013 08:59:42
All wheel rakes have the wheels turned by ground contact only. If your hay isn't too thick or wet the wheel rake will turn it fine. Granted a powered rake will turn a wetter,thicker windrow.
Phil H
04-28-2013 10:31:57
 Re: JD WHEEL RAKE in reply to Tx Jim, 04-28-2013 08:59:42
Thanks, I never new that, and it helps me make up my mind....
Leroy
04-28-2013 10:39:09
 Re: JD WHEEL RAKE in reply to Phil H, 04-28-2013 10:31:57
Also some say the tines hitting the ground pick up and put dirt in the row while others say it is not so, never was around one so I do not know but I do know a bar rake should have the tines 2" off the ground against on the ground.
Mike Aylward
04-28-2013 11:01:29
 Re: JD WHEEL RAKE in reply to Leroy, 04-28-2013 10:39:09
Actually, a wheel rake doesn't have to run in the ground to make the wheels turn. The crop running against them along with your own forward travel will make them turn. You can raise the wheels to where they just make contact with the ground and still get all the hay with no dirt in the windrow. Mike
Phil H
04-28-2013 18:56:22
 Re: JD WHEEL RAKE in reply to Mike Aylward, 04-28-2013 11:01:29
I guess the best is to try this type of rake, and see what it does. All I have seen is what is on U-tube and that is on a flat field under the best conditions....
Leroy
04-28-2013 16:25:02
All I know about them is what I read on here.
