planter hitch
Would you clarify what you mean by LOWER PART OF HITCH. Have 3 of those planters but there is nothing I would call a lower part to the hitch.
The later model 494 made 59 to 61, had same folding hitch that the 494A , which came out in 62.. Preacher man;There is a good planter slavage yard in Iowa; It was talked about on JD form a wk. or two ago. I'll see if I can find it, name & phone where given .. Are you far from Iowa..
I need the part that goes from the tractor hitch to the planter. It hinges back at the planter by taking 2 bolts out and loosening the others. The lower hydraulic cylinder mount is between these two pieces and the hitch bolts to the bottom of this. I only need the two side pieces. Mine are bent. I am located in central IL, but am willing to pay for shipping or I might be able to pick them up. Hope this helps. Thanks.
Should be able to find that at just about any bone yard. I was just at Wisconsin Tractor parts in Black Creek (ASAP ag parts) yesterday looking for fertilizer openers for our 495A, and they had some hitches there that would work.
Anything up to a 1240 would work for you. That's what we've got on our planter, after I used my brother's tractor with a 3 pt. drawbar to back it in the shed one year, and turned too short folding it up.
Donovan from Wisconsin
