TractorLinks.com
Re: Dearborn 19-59 Loader
old
04-26-2013 11:47:38
Well first off if you have the 19 inch tires up front you will want to change them out to the 16 inch so you can go wider on the tires. As for hyds it should have a hyd pump that runs off the crank shaft pulley which you will have to replace on your tractor for one that is drilled and tapped for the drive hub. When running a loader on that tractor you will also want something real heavy on the 3 point or the steering will be a bear
