BANDITFARMER
Hi Frank I have a guestion on the GT 1006 No-Till Drill, Ware do you get your parts from? While going over the drill today I found several loose bearings. I got them all tightened up and the seed tube adjusted like you said and did good till I got to the last one and found a bad bearing and hub assc. that are going to have to be replaced. The nut side bearing had been loose for a while and has eat the stub shaft up to ware it wont hold a bearing anymore. I have the number for Moore in Ireland 011-4428276644 and one for a dealer in Ontario Canada 416-247-7875 and was wondering if you know of any others that might be in the USA to get parts from? The part # in my book is #731710 for the hub and bearing and part# 730450 right and #730460 left bearings. The bearing I could read is a Timken DUO-FACE-PLUS( #L44600L on the seal) #L44642 Timken Made in England on bearing. I hope you might be able to give me some ideas before I start calling Canada and Ireland tomorrow or if you or anyone else know another source in the USA to get parts from. Thanks for any help you can give me. At least its the easiest one to work on. Bandit
