Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Frank Packard
frank packard
04-23-2013 05:23:39
Banditfarmer I usually get my parts direct from Moore. I order on line and they accept paypal only. If you need the bearing it has a Gleaner number 71326257. I also had to replace one of the shaft last year same problem that's when I repacked all the bearings. If you contact Moore their address is www.moore-unidrill.com and the person I've talked to is Rosemary Gregg very helpful as long as you have part numbers shouldn't be any problem. When I 1st got my drill I ordered parts from Bannerman's(Canada)and Moore direct, Moore's got here 1st and were cheaper inc.shipping. Good luck if you need info I'll help as much as I can. Frank
Banditfarmer
04-23-2013 13:19:05
 Re: Frank Packard in reply to frank packard, 04-23-2013 05:23:39
Thank You for the information, I got lucky my cousin has a small machine shop and is going to cut it down and put a sleave on it tig weld a turn it down to fit. Local Oliver dealer had bearings so I got lucky on that part. After planting is over I think I am going to put it in the shop and go through all the bearings on the openers and press wheels and repack them and check things out. Getting this fixed I should be good to go, I hope! I will have to get Moore a call to order some of the flexible rubber connectors, Have a couple that are not the best put will work for now. Its good to know there is someone else out there with one of these drills in use. Thanks You for your help. Bandit
