super99
I have this old Case disk, about 13'. I have been using it until this year. Now that I have the John Deere disk fixed, I'm thinking about selling it. The only problem with it is one of the angle irons on the hitch is busted. It's been welded before and broke again. Are these of any value to collectors? What's it worth? I'm thinking about asking $500 for it. What do you all think?
Where? I need one with good blades. Those case discs were about as good as they came for that time. Never seen one broke there, they would break the hitch if you put too big a tractor on them.
I just noticed that the hitch was extended. Do you know why that was done? Very interesting to see the things done to equipment to make it work for each individual farmer.
you evidently don't know much about a Case S/SA disk, they are very heavy compared to an RW jd or similar, built with alot of angle iron and 4 bearings per gang, they cut pretty good for their size
Kevin,
You should have said that you know nothing at all about any disc!! What are your thoughts about the tillage equipment that Case marketed in the 70s?
Loren the Acg.
I have an 8' and a 15' brother had a 11' dad had a 9' neihgbor had probly 18'it had small wings and dual wheels anyway all sizes are approx. as far as im concerned those were @ the time they were built and still about as good of finishing disk as you could find they were all built basicly the same way overbuilt compared to IH or Deeres of the same time
Found a book on model S disk dated 1953 I think is an older disk than the one in pic. mod.S78 7'1" cut Shipping wt.1503 lbs mod. S108 10'4" 1749 lbs mod.S138 13'9" 2356 lbs
