Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: New idea 486 baler
Caseyc
04-21-2013 19:32:46
When the arms are up the twine should be pinched on the knives. When you swing the arms down to start a tie, the twine is released, falls down into the hay and starts to tie. The arms work their way to the outside of the bale and when the arms hit the end, the twine is cut and pinched in place till the next bale. If that doesn't make sense I can try again.
Casey in SD
Dave320
04-22-2013 04:15:35
 Re: New idea 486 baler in reply to Caseyc, 04-21-2013 19:32:46
That was helpful. Guess will be easier when in use.
Caseyc
04-22-2013 05:43:40
 Re: New idea 486 baler in reply to Dave320, 04-22-2013 04:15:35
If you want it "ready to go" then you can run the twine through the tubes. You'll find a cable by the knives that pivots a block that pinches the twine so the knives can cut it. Pull on that cable, run the twine over the knife and release the cable. The twine will be set now. It sounds complicated as heck but it really isn't.
Casey in SD.
Dave320
04-22-2013 18:23:14
 Re: New idea 486 baler in reply to Caseyc, 04-22-2013 05:43:40
Ok will try that! You have been very helpful!!
dave320
06-18-2013 18:36:09
 Re: New idea 486 baler in reply to Dave320, 04-22-2013 18:23:14
New idea 486. On the left bottom the outside belt is running about a 1/2 inch too far to the outside and is currling over. It should be ajusted to the inside more. Would you have to tighten it or loosen it or how would i solve this. PS this is the first that i ran the machine since i bought it. Just to make sure every thing works. Thanks
Copyright © 1997-2015 Yesterday's Tractor Co.
