TractorLinks.com
Re: Fixing a Loose/Worn-out Disk Harrow - Have some Question
rankrank1
04-21-2013 08:47:13
Yep add zerks if not already present. No use using high dollar grease either. Use the cheapest stuff you can find there and use it often. As they get more sloppy the expensive grease disappears just as fast as the cheap stuff since it is not sealed in anyway.
Dad had on ole disk that was well worn in those bearings. The wear really does not hurt anything at all as long as they internal hub can not work it ways out of the outer hub.
Tip: We always saved our broken blades and cut washers out of those in order to make washers of end of axle shafts if needed to tighten those up.
