Need plow ID
NEKS
Looks older then me, wait it has rubber tires.
Definately an Oliver. I had a couple yrs ago. Best one was a two bottom 16 inch I ran behind a 60 JD. Really liked that plow. Also had a 3/16 behind a 730, worked just as good and had hydraulic hill side hitch.
If you have a tractor with a 56" wheel tread not too bad but if your tractor is one with the fixed wheel tread for cultivating 2 - 40" rows so the tread is about 80" then it becomes impossible as it cannot be moved to the side like all the others can. I had that hitch on a plow and the tractor was on 72" tread width and you could not set it for that wide and have it pulling corectly, one reason got rid of that plow. If would have known was later going to get a tractor with that 56" wheel tread (on that width the hitch will set straight, not on a 45* angle like with the wide tractors) would have kept the plow and repaired the clutch.
