Yesterday's Tractor Co.
Shop Now View Cart
Re: Need plow ID
04-21-2013 07:16:12
Oliver is the only company to use that hard to adjust type of hitch.
04-21-2013 07:30:25
 Re: Need plow ID in reply to Leroy, 04-21-2013 07:16:12
What is so hard to adjust about it?
04-21-2013 07:57:57
 Re: Need plow ID in reply to rustyplow, 04-21-2013 07:30:25
If you have a tractor with a 56" wheel tread not too bad but if your tractor is one with the fixed wheel tread for cultivating 2 - 40" rows so the tread is about 80" then it becomes impossible as it cannot be moved to the side like all the others can. I had that hitch on a plow and the tractor was on 72" tread width and you could not set it for that wide and have it pulling corectly, one reason got rid of that plow. If would have known was later going to get a tractor with that 56" wheel tread (on that width the hitch will set straight, not on a 45* angle like with the wide tractors) would have kept the plow and repaired the clutch.
04-21-2013 07:44:20
I guess one set screw vs a dozen bolts is "hard".
