Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Fixing a Loose/Worn-out Disk Harrow - Have some Question
RTR
04-18-2013 19:40:00
Thanks so much guys. I've learned a lot and will help home get e, greased and back together. I'm guessing he'll have to drill and tap each one to fit a grease zerk in them since they don't have one. But we will look closer this weekend. Thanks!
Paul
04-19-2013 11:35:52
 Re: Fixing a Loose/Worn-out Disk Harrow - Have some Question in reply to RTR, 04-18-2013 19:40:00
On the top side, where the angle iron goes across the bearing, there will be a 3rd hole in the angle iron. Grease zerk should be recessed in that hole. Newer models they put a short pipe bib in and put the zerk up higher so it didnt fill with dirt.
Anyhow, that would be most of them.
Paul
rankrank1
04-21-2013 08:47:13
 Re: Fixing a Loose/Worn-out Disk Harrow - Have some Question in reply to Paul, 04-19-2013 11:35:52
Yep add zerks if not already present. No use using high dollar grease either. Use the cheapest stuff you can find there and use it often. As they get more sloppy the expensive grease disappears just as fast as the cheap stuff since it is not sealed in anyway.
Dad had on ole disk that was well worn in those bearings. The wear really does not hurt anything at all as long as they internal hub can not work it ways out of the outer hub.
Tip: We always saved our broken blades and cut washers out of those in order to make washers of end of axle shafts if needed to tighten those up.
Leroy
04-19-2013 06:04:05
Probably broke off or come out and holes filled with dirt.
Copyright © 1997-2015 Yesterday's Tractor Co.
