Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere Three Bottom Plow
Leroy
04-18-2013 19:00:47
That looks like an adapted 8" wheel, the orignal would be 12" with a 4:00 X 12 tire. And that is definatly not a correct landside.
ET
04-19-2013 04:56:18
 Re: John Deere Three Bottom Plow in reply to Leroy, 04-18-2013 19:00:47
The early 813 plow used the pneumatic 8" wheel and later a hard rubber wheel. The bigger 12" wheels like on trailer plows came into use with the 810 series mounted plows. The short cast landside is correct with that style tailwheel. The longer landside will hit the linkage and bend it when the rear bottom trips. Guess how I know?
ET
04-19-2013 05:06:47
 Re: John Deere Three Bottom Plow in reply to ET, 04-19-2013 04:56:18
I just looked at the new picture again and noticed it does have the gauge wheel on it. The 813 plow was meant to be used with the JD800 series 3pt hitches on the 50-60-70 and needed the gauge wheel because the was no depth control with that system.
WI Rick
04-19-2013 05:14:56
 Re: John Deere Three Bottom Plow in reply to ET, 04-19-2013 05:06:47
Thanks, do you know where I can get new shares?
ET
04-19-2013 07:28:06
 Re: John Deere Three Bottom Plow in reply to WI Rick, 04-19-2013 05:14:56
Parts are available from JD. They are high speed bottoms. You need to know if they are 14"or16" bottoms and 3or4 bolts holding the share on.
