Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: IH grain drill
Case Nutty 1660
04-05-2013 11:50:24
is it from a disc or hoe drill? I have both types ob parts drills will get some pics for you
Case Nutty 1660
04-05-2013 12:02:39
 Re: IH grain drill in reply to Case Nutty 1660, 04-05-2013 11:50:24
sorry now I see the pic below will check mine see if they are the same style
Darryl 2Ms
04-05-2013 16:31:50
 Re: IH grain drill in reply to Case Nutty 1660, 04-05-2013 12:02:39
Hi!, I guess you would call it a disc drill. It has single disc openers. Any help would be appreciated. Thanks! Darryl
Case Nutty 1660
04-05-2013 17:38:42
 Re: IH grain drill in reply to Darryl 2Ms, 04-05-2013 16:31:50
here is what mine has for feed tubes
1 pic is the drill (sorry about the grass)
2nd is a feed tube installed
3rd is the feed cup with the feed tube removed
4th is a close up of the feed cup
5th is the complete feed tube assembly
hgope this helps if these are like yours let me know this drill has a full set that looks good 14 or 15 on it, on mine all you have to do is pull the cotter pin to remove them cnt
Darryl 2Ms
04-06-2013 17:13:46
 Re: IH grain drill in reply to Case Nutty 1660, 04-05-2013 17:38:42
Hello, you can also reach me at toolguy56@aol.com if that is easier for you. Put Ih grain drill in the topic line so i dont go past it! thanks
Darryl 2Ms
04-06-2013 17:00:30
Hello! My cups/receivers are alittle different. My drill is a double run type( grain and fertilizer) so there is a baffle in the middle of the cup. The notch looks a little different too. But I think I can make yours work. How much would you want for the full set of cups and tubes? And you say you were going to look at the opener this weekend? Here's hoping! Let me know. I appreciate the help and the pics. I know its time consuming taking pics, loading in computer and posting online. Many thanks big guy... ..... Regards Darryl
Copyright © 1997-2015 Yesterday's Tractor Co.
