Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: New Idea Easy Flow
Mike Shuler
04-03-2013 20:37:30
Red, I just bought a 12ft. John Deere that looks to be identical to the Easy Flow. I don"t have a manual yet, so I am looking for the same info as you. I want to spread dry fine Ag lime. Where do I set it for a ton per acre at 5mph?
maxwell99
04-04-2013 06:07:44
 Re: New Idea Easy Flow in reply to Mike Shuler, 04-03-2013 20:37:30
mike,
I have a new idea 12 ft spreader.
I do not have the spreader rates, but I have used mine to spread lime before.
it worked very well, but you do not want to load it very deep as lime is very heavy. also the lime works best if its dry
you want to wash and oil the spreader after lime use.
Mike Shuler
04-10-2013 08:48:30
 Re: New Idea Easy Flow in reply to maxwell99, 04-04-2013 06:07:44
Wanted to follow up on the spreader... I put 4 ton of lime down yesterday and it worked great. The lime has the consistancy of baby powder and feeds with no problems. My rate is about 2 ton per acre, which is good for this ground as it has not seen lime in 8 years. I am going to put another 4 tons on this weekend, clean the spreader and start plowing.
Mike Shuler
04-04-2013 12:06:55
Thanks... this is good to know. I have heard of guys having some issues with lime bridge inside and having to poke at it to get it to feed. Hence why I will pay a little more for crushed fine lime than the rec-mix. I just hope I am not on and off the tractor seat a million times. I guess I will go by trial and error and go from there until I get my manual.
