U bolts for a mystery cultivator
romanccm
04-03-2013 09:41:49
I have a three point hitch cultivator that fits my ford n perfectly. It has spring teeth that bolt onto 1 3/4" posts that slide up and down in brackets secured by a u bolt.
I would like to use it as a harrow as my drags are worn to shreds-- I have the extra tines, posts and there were two extra mounting brackets on there. All I need are the u bolts.
They are 5/8" stock 2" center to center and 2 3/4 from foot to top of throat. No one seems to carry the things-- do any of you guys have a source for hardware like that?
ben there
04-03-2013 20:14:55
 Re: U bolts for a mystery cultivator in reply to romanccm, 04-03-2013 09:41:49
Grade 8 all thread would work.
hd6gtom
04-03-2013 16:22:48
I had our local welding shop make some for my 1800 Oliver hub, cant tell them from the factory ones.
rrlund
04-03-2013 10:59:35
You could try Agri Supply. Too many pages there for me to sift through.
JMS/.MN
04-03-2013 10:09:32
You could use two regular bolts and two pieces of flat steel, drilled for the bolt pattern..... ..use as a clamp.
romanccm
04-03-2013 11:04:05
 Re: U bolts for a mystery cultivator in reply to JMS/.MN, 04-03-2013 10:09:32
now that's thinking! Been looking at the danged thing too much to step back and think of an easy solution. Thanks man!
JMS/.MN
04-03-2013 21:05:15
 Re: U bolts for a mystery cultivator in reply to romanccm, 04-03-2013 11:04:05
Gracias! Sometimes that works....sometimes not- just depends on the situation. BTDT many times in 40 years of farming, configuring, trying the cheap alternative! Yeah, I"m a conniving cheapskate! I"ve built some machines, been repairing and modifying for decades. Dad did the same. If you go back to the early years of mechanized agriculture..... most mods were invented by farmers, not engineers.
