JD BW disk update
super99
04-02-2013 18:36:02
I checked around for blades. Farm & Fleet only has notched blades at $25ea. Shoup's has smooth blades for $26ea for 12 or more. Sloan Express has 18" 9ga blades for under $17 ea. I order 24 blades, with shipping, total was $502. I checked with Sloan about bearings, they couldn't match the JD numbers, I will call Shoup and see if they can match them up. Worked on it some tonite, got 1 bearing beat off the shaft on the last gang. I guess I'll find out if the shafts break after welding on them this spring. Chris
super99
04-03-2013 17:50:28
 Re: JD BW disk update in reply to super99, 04-02-2013 18:36:02
I called Shoup this afternoon, They have the bearings. At John Deere you have to buy the bearing, races and seals seperate. Shoup had bearing, races and seals in a kit for $84.95. JD is about $115 for everything you need. Ordered 2 bearings.
David from Kansas
04-03-2013 16:29:54
third party image
third party image
If either of you guys need a good clevis hitch (JD original part #B15572) I have one for sale for $15 plus shipping. Has had holes built up but was a good job. No cracks or welds on main casting. Thanks.
super99
04-03-2013 17:43:47
 Re: JD BW disk update in reply to David from Kansas, 04-03-2013 16:29:54
Let me check mine out and see what it's like. Chris
tomstractorsandtoys1
04-02-2013 19:55:07
I have a BWF to start on latter this week,except we are putting verticle till blades on it instead of discs.We are planning on adding a harrow and a rolling basket as well.Ours appears to be froze up like yours as well.
