IHC grain drill
sam in mo
there is a post on a grain drill a couple of post down. Does anyone know where you can buy the spring loaded feed tubes with the keepers from? Thanks
You get new rubber accordion tubes from Case-New-Fiat. You have to take a long pin and a hammer to clean the rust out of the opener boot, and push the spigot end of the tube down in there. of course it doesn't look original, but it'll work until some of those ribbon tubes turn up somewhere.
I assume you are referring to the spring steel spiral wound seed tubes. Certainly would be great if someone began to reproduce them. Was looking for some a couple of years ago and an individual indicated he had several that were NOS. I needed 16 so didn't pursue it. They are so much better than the rubber hoses which overtime can sag and form pockets distrupting seed flow. The rubber hoses were just an OEM cost savings.
