Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Progress on the BW Disk
DeltaRed
03-27-2013 22:13:55
Chris,The next time you have a 'stubborn' nut,heat it to cheery red.Imediately douse/immerse in cold water till cold.The sudden contraction will break the rust.You should be able to easily remove it,possibly even with your fingers.Old welder trick.Also called the "screaming bucket" method...One of my favorites.Steve
super99
03-28-2013 02:03:56
 Re: Progress on the BW Disk in reply to DeltaRed, 03-27-2013 22:13:55
I thought about that, but wasn't sure if the cast iron would take it or bust.
DeltaRed
03-28-2013 07:25:28
 Re: Progress on the BW Disk in reply to super99, 03-28-2013 02:03:56
Direct the heat to the steel nut.That the cast wont get so much heat,it should be ok.If you're real careful,you can 'blow' the nut off with minimal to NO damage to the bolt threads.Done that several times...
