Cordova Steve
Well I thought I'd try to give back a little here. I just aquired a brochure with spec.'s on EWC made Oliver Wagons models as listed in the topic. This brochure also lists optional bolster set ups. a EW-663 is the Rocking Bolster Assembly and the EW-664 is the spring bolster assembly. These were not available on the 5th wheel 5005 for ovbious reasons. Also some info on a 630 power unloader if anybody ever needs it. It talks about two hoist options a 5230 Hy-lift and a 5250 Super Hy-Lift Hoist. A model 610 galvanized barge box, a model 5115 deck, a model 5125 and 5126 galvanized flare box, a model 770 and 5114 barge box.
I'm still trying to figure out the model number for sure on the "meadow Green" colored EWC wagon I have. It's not an Oliver or John Deere Green. It's suppose to be a 550 or 551 but I'd sure like to find another one with a model number tag on it to compare to. You can find pictures in a few earlier posts of mine. Keep your eye's open if you see a wagon that funny green color and check it out for me if you could.
