steve in wi
Right now i use a niemeyer rotary,works good for first crop which is mostly alafafa and little grass.I can use that for a tender also.When it comes too second crop alot of trips around a field to get the windrow together. I was thinking a wheel rake a 3pt one i could go faster and it picks up more hay.when i get to the end just pick up.ON wheel rakes is their a difference on the wheel rakes ?some wheel rakes just use small regular rakes tines and some use the longer flexiable tines .i,am in s.e. wi and its allways alafafa crop.Not sure if wheel rake would work or just stick with a rotary.thanks steve
