Fast hitch disc plow application?
Anonymous-0
I have an International 300 Utility with a fast hitch. I found a two bottom fast hitch disc plow local with small fast hitch points. If I add the 1/2" spacer to the fast hitch points, will that plow work OK with my 300U? I just need to plow a small garden.
>My 350U has the factory spacers for that >reason. Jim
Do these stay attached?
Thanks, looks like I'm set (if I can strike a deal).
It will "work". That plow was designed to go behind a Farmall Super C that you could easily adjust the wheels to the proper width.
That would be the only possible issue is getting your wheels set narrow enough.
