TractorLinks.com
Re: John Deere Trailer Plow
Brian Fulk
03-20-2013 06:32:20
Ive Got the same plow but is a 3 14" and has newer style rims. what do i have?
long green line man
03-20-2013 08:10:39
 Re: John Deere Trailer Plow in reply to Brian Fulk, 03-20-2013 06:32:20
If your 3x14 plow has newer disk style wheels (6 bolt rim) it"s a 666H, or 555H 4 bolt rim.. with or with out, trip back standards?.....
Brian Fulk
03-20-2013 08:20:13
 Re: John Deere Trailer Plow in reply to long green line man, 03-20-2013 08:10:39
And since the moldboards dont trip, i assume it shouldve came with a clevis syle hitch that someone obviously took off because it just hooks to drawbar with hitch pin now.
long green line man
03-20-2013 20:29:40
 Re: John Deere Trailer Plow in reply to Brian Fulk, 03-20-2013 08:20:13
There were 3 dif. style hitchs used on stiff standard plows,(non-tripping);spring cushion;spring cushion trip style(like Mcoy's)& tractor clutch release (knee cap breaker) style.. check out PC-524 .. JD parts .com .....Some Rice plows used a stiff pin hitch.. like the trip bottom plows used...
Brian Fulk
03-20-2013 08:15:25
Long green mile man mine does have 4 bolt rim and moldboards dont trip.
AJB-830
03-20-2013 07:03:00
Brian, Without seeing a picture my guess is that it would be a JD 555. It could also be the newer JD F620. Does it look like the attached picture of my JD 555 plow? Al
Tyler-MO
03-22-2013 05:41:01
 Re: John Deere Trailer Plow in reply to AJB-830, 03-20-2013 07:03:00
Here is something I'm working on to help guys ID their plows. I get so many calls for plow parts and only have so much time...so if the website can help eliminate the need to 20 questions over the phone much time would be saved.
Tyler
AJB-830
03-23-2013 18:45:24
 Re: John Deere Trailer Plow in reply to Tyler-MO, 03-22-2013 05:41:01
Tyler, Looks like you have pictures of all my plows which include 55, 555, 66, F620, and 810. Al
Brian Fulk
03-20-2013 07:37:58
Thanks AJB its identical to your 555. I just bought it for my jd 60 standard, hope it pulls it in our clay ohio ground.
BushogPapa
03-21-2013 10:33:57
 Re: John Deere Trailer Plow in reply to Brian Fulk, 03-20-2013 07:37:58
Should pull it..as long as it is a Gasoline Only" 60 and GOOD Tires.. The 60 was really an improved JD "A", with about the same engine..only the dual-Throat induction and Live PTO were the difference..with a slight increase in Compression.. You will KNOW, when you get into some Dry Black-jack or yellow Wax...!! I am in Ohio too..just North f Columbus..
The 620/630 have a smaller engine but have way more pulling power, stock..would not hesitate to hook a 4x14" (Mounted) to one of them.. Ron
