Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: jd rotary mower clutch stuck
[Return to Forum]
Pknapp
03-09-2013 14:57:41
71.164.106.56
Bought a JD 509 cutter and the manual says to loosen
the clutch adjusting nut and free up the clutch. I
loosend the nut but the clutch plates are rusted
fast. Any ideas on freeing the plates up?
[Reply]   [No Email]
John A.
03-09-2013 21:29:17
64.128.16.238
 Re: jd rotary mower clutch stuck in reply to Pknapp, 03-09-2013 14:57:41
Pknapp, After you loosen the nut run the shredder in tall heavy weeds that will usually break it loose. But since it is already not budging you may have to Disassemble the Slip-Clutch unit and free it all up, But Chances-Are you will destroy the fiber disk and need new ones then!
Note
next Fall, Loosen the nut 2 to 4 turns before you put it up for the Winter. Also get and old Wash tub and turn it upside down over the Gearbox for the winter season. Come spring service the shredder and push it just hard enough to slip the clutch a little then tighten back the 2 to 6 turns you took off the previous fall and you are good to go for the summer! Simple slip-clutch maintence! Hope this helps!
Later,
John A.
Works on any shredder!
[Reply]  [No Email]
BushogPapa
03-09-2013 19:42:07
173.88.51.117
Now is a good time to see...
With the pressure off the plates, get them loose...use an air-hammer or just a Ball-Pien and jar it until they come loose..
Might even be able to drive a sharp Putty knife between the plate and the friction lining to get it loose..
If the friction plates are bad--now would be the time to replace them.
If they are still OK, I would leave the pressure light and let it slip a while and shine the surfaces..
A little graghite won't hurt either..
Ron..
[Reply]  [No Email]
frankmn
03-09-2013 17:11:38
184.7.172.39
Use it with the nut loosened up. They will break free and you will wish they were locked up again because you will be buying parts.
[Reply]  [No Email]
Tx Jim
03-09-2013 15:38:18
67.142.163.21
Tap the clutch plates with a hammer or try mowing with not tension on the Bellville washers.
[Reply]  [No Email]
Pknapp
03-09-2013 15:53:07
71.164.106.56
 Re: jd rotary mower clutch stuck in reply to Tx Jim, 03-09-2013 15:38:18
Tried tapping on them but they are rusted solid
[Reply]  [No Email]
Tx Jim
03-09-2013 16:08:46
67.142.163.21
 Re: jd rotary mower clutch stuck in reply to Pknapp, 03-09-2013 15:53:07
Have you tried soaking clutch in your favorite penetrating oil?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
