TractorLinks.com
Re: Hesston 5580 round baler
Retired Farmer
03-09-2013 06:28:05
I had one years ago. I thought it was a good baler. Make sure you check the belt roller bearings. I had a couple go out. Not too much fun to replace. Make sure the electric motor on the twine arms works. It was expensive to replace. I converted mine to hydraulic cylinder when it went out. If you happen to buy it and need to remove any bolts for any reason, Locktite the threads when you put it back together. Seems to be a lot of vibration in the machine and the bolts will work loose. Cost me several thousand dollars worth of bent chamber parts to find that out.
