TractorLinks.com
Re: Switching Knotters on a JD 14 T
David1
03-08-2013 06:24:06
I have found a baler that sat out with hay in the chamber and has rotted out. The knotters look ok. Have you ever taken pulled the shaft that runs thru the knotter frames? How hard is it to do? I have a broken frame on the left hand side. Is it possiable to weld it back together while still on the shaft? Thanks for any info.
ErnieD
03-08-2013 08:24:13
 Re: Switching Knotters on a JD 14 T in reply to David1, 03-08-2013 06:24:06
Did it on a 336(?) a long time ago. Shaft was broke. Beat the old one out with a lead hammer. Long job. Search out an arbor press. Count your washers, same in and out.
Make sure the needle carrier is not bent or warped.
Time by the book, make sure flywheel rotation is correct to take the slack out of the chains.
Check needle clearances by running through by hand.
