Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 24T Baler problem
GarryinNC
03-02-2013 18:17:52
I thought that what broke out of time needles was the hay that is being pushed by the plunger head, not the head itself. On a New Holland at least, the needles come up as the plunger head enters the chamber. The head has slots in it for this reason. Someone tell me if I am goofed up on this.
Timing is everything, at least on square balers!
Garry
Tx Jim
03-03-2013 04:54:15
 Re: 24T Baler problem in reply to GarryinNC, 03-02-2013 18:17:52
Garry
You are correct. Without hay in chamber PH will not break/contact needles while tying cycle is completed. I've also seen on JD 336 balers the pin that connects the crank arm to PH get loose/slide over and bend/break needle when needle went up through slot in PH on tying cycle.
