Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Kverneland plow
RodInNS
03-02-2013 10:05:37
The agronomic benefit is there with these plows for anyone that has to deal with rock. I can understand it being of less value if you don't have to deal with rock. The plow that someone pictured... the AB85 will basically plow continously in just about any kind of ground at 4-5 mph unless you hit a rock the size of a tractor. So there's a considerable productivity gain there over even a manual reset trip bottom.
A lot also depends on just what generation you were from when a plow was bought. Around here tractors did not become common until after the war... so most bought 2 bottom plows to go with those Ford's and Fergusons. These were mostly scotch bottom Ferguson Sherman plows... or some Dearborns. As time wore on... the bigger tractors that landed around here were the 990 and 1200 Brown's and with them came 3 bottom Brown plows with Scotch bottoms and some with midwest style bottoms. When those went to the woods they were almost universally replaced with 4 bottom Kvernelands... and when most people saw how those worked next to a Brown or a Dearborn... lets just say the salesman didn't have to work for his comission. That first generation were mostly Hydrien's and they're mostly gone to the woods now as they were replaced with the AB's (pictured) and #8 bottoms or by BB semi's with the same bottom. The variable width and auto reset was the main reason for replacing the older generation.
IH was never a force in this area as the dealer died sometime around the end of the letter series tractors and Massey basically swallowed the market they had. Deere has never been a contender here until modern times. The first 2 lunger I ever saw was when I went to college and someone was overhauling one in the engineering shop.
Rod
Leroy
03-02-2013 18:21:55
 Re: Kverneland plow in reply to RodInNS, 03-02-2013 10:05:37
Nobody around here ever saw a scotch bottom in the ground, most would not know what they are.
RodInNS
03-02-2013 18:45:47
 Re: Kverneland plow in reply to Leroy, 03-02-2013 18:21:55
I'm guessing you don't have sod... or not heavy sod.
Rod
NY 986
03-02-2013 11:43:18
The better off farmers before WWII had drawbar type tractors. IH and to a lesser extent Deere dominated the general farm equipment market. Up to the late 1950's a Deere and/ or IH dealer could be found in any sizable town here. Farmers understood that generally better pricing and service went hand in hand with giving these dealers a majority of the farm's business. Specifically, most of these farms used IH or Deere trailer-type plows that worked without modification for the drawbar type tractor.
Copyright © 1997-2015 Yesterday's Tractor Co.
