| Implement Alley Discussion Forum |
Topic: Re: 24T Baler problem
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| billinaz
03-02-2013 06:53:26
184.20.254.229
donjr, the needles are always partly cycled when this happens, so would this rule out your suggestion? |
| donjr
03-02-2013 08:51:53
72.71.185.52
Re: 24T Baler problem in reply to billinaz, 03-02-2013 06:53:26
| You have to look at your tying cycle. IF the needles are tying, returning to home, then bouncing off home, look at your brake. If the needles are ALL the way back, look at your chamber stop. It's there to protect the needles. If the needles are stopping anywhere forward of home, there has to be a reason for it. But the shearing of the safety bolt is usually due to the bale head stop being into the chamber for some reason. If the needles are homed, it has to be an adjustment problem or a lube problem on the safety stop. Big thing is, you do not want the needles anywhere near the chamber on the compression stroke of the head. |
| Tx Jim
03-02-2013 09:24:51
67.142.163.23
Re: 24T Baler problem in reply to donjr, 03-02-2013 08:51:53
| Quoting Removed, click Modern View to see
Every properly operating sq baler that I owned or worked on was on the "compression stroke" when the needles were pulled into the bale chamber & knotter. |
| Tx Jim
03-02-2013 09:30:58
67.142.163.23
Re: 24T Baler problem in reply to Tx Jim, 03-02-2013 09:24:51
| BillinAZ
If the needles are partially in the bale chamber I strongly suspect the needle brake is at fault. The random flywheel shear bolt problem leans toward faulty needle brake. In all my years repairing/owning JD sq balers I can't remember the trip dog once engaged not pulling needles through their cycle. |
| donjr
03-02-2013 12:28:01
72.71.185.52
Re: 24T Baler problem in reply to Tx Jim, 03-02-2013 09:30:58
| JIm, the problem we had was the needle arm was engaging the dog and holding it out of the chamber, but not far enough. The pitman had a couple of angular bends, and a clevis on the needle arm. The pitman had straightened some over the years because of the bends in it, and allowed the dog to protrude just up into the chamber, and the head would catch it at an irregular time and shear the shear bolt. It may have just been wear in the connecting pins, but was a pain in the ask to find. And I may be wrong, but my needles on my 14T come into the chamber during the decomp stroke, tie and are moved out during the start of the compession stroke, so they are not in the chamber at all when the head is the chamber.... |
| Tx Jim
03-03-2013 04:48:30
67.142.163.22
Re: 24T Baler problem in reply to donjr, 03-02-2013 12:28:01
If your 14T operates as you describe it needs to be "timed correctly". Yes the PH stop mechanism can wear/stretch to allow stop to contact PH or arm prematurely. This is common malfunction on newer JD balers such as the 336. The arm(boomerang parts key #12) that needle frame contacts stretches(angle increases) and allows this to happen. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
