Yesterday's Tractor Co.
Shop Now View Cart
Re: 24T Baler problem
03-01-2013 10:38:33
Take a look at your chamber dog. On some JD balers, especially with some wear (which a 24T has) the operating rod for the head stop has stretched some and allows the dog to remain in the chamber even after the needles are clear just enough to shear the pin by stopping the head on it's stroke. Make sure the stop is clear of the chamber and operating freely. If it continues to do so, shorten the turnbuckle on the pitman arm for it a couple of turns.
03-02-2013 06:53:26
 Re: 24T Baler problem in reply to donjr, 03-01-2013 10:38:33
donjr, the needles are always partly cycled when this happens, so would this rule out your suggestion?
03-02-2013 08:51:53
 Re: 24T Baler problem in reply to billinaz, 03-02-2013 06:53:26
You have to look at your tying cycle. IF the needles are tying, returning to home, then bouncing off home, look at your brake. If the needles are ALL the way back, look at your chamber stop. It's there to protect the needles. If the needles are stopping anywhere forward of home, there has to be a reason for it. But the shearing of the safety bolt is usually due to the bale head stop being into the chamber for some reason. If the needles are homed, it has to be an adjustment problem or a lube problem on the safety stop. Big thing is, you do not want the needles anywhere near the chamber on the compression stroke of the head.
Tx Jim
03-02-2013 09:24:51
 Re: 24T Baler problem in reply to donjr, 03-02-2013 08:51:53
Every properly operating sq baler that I owned or worked on was on the "compression stroke" when the needles were pulled into the bale chamber & knotter.
Tx Jim
03-02-2013 09:30:58
 Re: 24T Baler problem in reply to Tx Jim, 03-02-2013 09:24:51
If the needles are partially in the bale chamber I strongly suspect the needle brake is at fault. The random flywheel shear bolt problem leans toward faulty needle brake. In all my years repairing/owning JD sq balers I can't remember the trip dog once engaged not pulling needles through their cycle.
03-02-2013 12:28:01
 Re: 24T Baler problem in reply to Tx Jim, 03-02-2013 09:30:58
JIm, the problem we had was the needle arm was engaging the dog and holding it out of the chamber, but not far enough. The pitman had a couple of angular bends, and a clevis on the needle arm. The pitman had straightened some over the years because of the bends in it, and allowed the dog to protrude just up into the chamber, and the head would catch it at an irregular time and shear the shear bolt. It may have just been wear in the connecting pins, but was a pain in the ask to find. And I may be wrong, but my needles on my 14T come into the chamber during the decomp stroke, tie and are moved out during the start of the compession stroke, so they are not in the chamber at all when the head is the chamber....
Tx Jim
03-03-2013 04:48:30
 Re: 24T Baler problem in reply to donjr, 03-02-2013 12:28:01
If your 14T operates as you describe it needs to be "timed correctly". Yes the PH stop mechanism can wear/stretch to allow stop to contact PH or arm prematurely. This is common malfunction on newer JD balers such as the 336. The arm(boomerang parts key #12) that needle frame contacts stretches(angle increases) and allows this to happen.
03-01-2013 14:05:50
Also the drive dog gets sticky and won't hold to pull the needles thru on the tying stroke. Penetrating oil is your friend to loosen the dog up.
