Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: JD 1209
[Return to Forum]
djm75
02-22-2013 04:25:21
206.72.19.191
I am looking at buying a JD 1209 haybine just looking for some input on them good bad or what have you. Thanks
[Reply]   [No Email]
Fff
02-23-2013 16:31:25
68.191.62.84
 Re: JD 1209 in reply to djm75, 02-22-2013 04:25:21
I had a 1207 for years, same machine exactly really but 2feet shorter. If you take the time to read the manual and get it adjusted correctly they cut very well. I used to mow at 3 mph in reed canary grass 4ft tall and it never plugged. They are elderly machines now so look at the wobble box and rollers.
[Reply]  [No Email]
NY 986
02-23-2013 06:20:39
67.142.178.27
I guess I am late to the discussion but here goes. I think at the serial number break Tx Jim mentioned Deere also improved the knife bar head assembly. I also believe this happened fairly early in the production run so there were many model years made with the improvement. They were made from the early 1970's (1971?) through 1983. They were one of those products that showed up on a variety of farms regardless of the brand of tractor there along with the 336 baler and 7000 planter back then. As many 1209's back in the day around here as there were NH or Hesston's.
[Reply]  [No Email]
Tx Jim
02-23-2013 06:34:53
67.142.163.26
 Re: JD 1209 in reply to NY 986, 02-23-2013 06:20:39
I think you're correct on the updated knife head but I would have thought those old type ball joint heads had gone to China by now.
[Reply]  [No Email]
NY 986
02-23-2013 10:08:16
67.142.178.27
 Re: JD 1209 in reply to Tx Jim, 02-23-2013 06:34:53
I thought the wobble mounts were different as well but I have only seen the newer assemblies. I wanted a brand new 1219 when they came out in 1984 but I was in college so we bought a used NH to save money.
[Reply]  [No Email]
Tx Jim
02-23-2013 04:25:54
67.142.163.26
 Re: JD 1209 in reply to allen in texas, 02-22-2013 04:25:21
Scott(MO) said: (quoted from post at 01:39:23 02/23/13) When cutting clover, I experimented with the reel speed and found that it worked better with a higher reel speed. Never tried the angle of teeth.
I'll have to say that Tyler is right though about belt slippage being a problem sometimes too.Scott
When belt slippage is a problem have you tried tightening or replacing the belt?
This post was edited by Tx Jim at 04:26:37 02/23/13.
[Reply]  [No Email]
Scott(MO)
02-24-2013 00:02:42
173.186.181.107
 Re: JD 1209 in reply to Tx Jim, 02-23-2013 04:25:54
Yes, worked on tightening and changed the belt
[Reply]  [No Email]
Tyler-MO
02-22-2013 15:56:24
50.40.179.233
I cut a lot of acres with a 1209 years back. The only problems we had were the reel drive belt slipping and broke a U joint on the gear case to roll drive.
Something else to be aware of is the urethane rolls. I've seen some that had gotten hole(s) in one or both rolls and it seems that the urethane can seperate from the roll...last time I checked new rolls from JD weren't available. Just be sure to turn it through and inspect the rolls carefully.
We would also replace some plastic bushings in ends of the reels from time to time as they would wear and get sloppy.
Good luck and happy hunting!
Tyler in IL
[Reply]  [No Email]
Scott(MO)
02-22-2013 11:21:17
173.186.181.107
I have always liked mine although it doesn't do the greatest job in heavy clover and transportation down narrow roads can be tricky (wish it was a center pivot instead to one side.) But all in all, a pretty dependable machine.
[Reply]  [No Email]
Tx Jim
02-22-2013 12:50:11
67.142.163.20
 Re: JD 1209 in reply to Scott(MO), 02-22-2013 11:21:17
On cutting clover have you checked to be sure the reel speed & setting of teeth angle is correct for that crop?
[Reply]  [No Email]
Scott(MO)
02-22-2013 22:39:23
173.186.181.107
 Re: JD 1209 in reply to Tx Jim, 02-22-2013 12:50:11
Scott
[Reply]  [No Email]
Tx Jim
02-22-2013 12:49:07
67.142.163.20
[Reply]  [No Email]
ron wis
02-22-2013 04:51:14
69.131.200.14
Bought one new 1977. If you have small rocks in field you will learn to duck the reel runs pretty fast and it will launch rocks at ya. Look at gearbox mounting plate for cracks. Cut a lot of hay with it very little trouble.
[Reply]  [No Email]
Scott(MO)
02-22-2013 22:41:50
173.186.181.107
 Re: JD 1209 in reply to ron wis, 02-22-2013 04:51:14
I know what you mean about the rocks flying ron. I hit a box turtle a couple of years ago and he took quite a ride!
Scott
[Reply]  [No Email]
Tx Jim
02-22-2013 05:24:27
67.142.163.27
Besides looking for cracks on the gearbox mounting bracket if it's had much welding done on the bracket run don't walk away. Also check to be sure sickle drive arm is tight on wobblebox. I'd prefer the machine after SN 285001 because it will only have one lift cylinder. The earlier units with 2 lift cylinders(master & slave) have been known to raise platform uneven.
This post was edited by Tx Jim at 05:26:32 02/22/13.
[Reply]  [No Email]
Texasmark1
02-22-2013 06:31:39
198.45.243.137
 Re: JD 1209 in reply to Tx Jim, 02-22-2013 05:24:27
The comment about the drive arm on the wobble box cannot be
overemphasized. It must be tight and when the manual says
torque to 150 ft-lbs, it means just that. Failure to comply results in
the bar breaking on the drive end and it doesn't take long, even
with a new bar.
BTDT more than once.
Mark
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
