TractorLinks.com
Re: IH 990 SICKLE BAR
Phil H
02-20-2013 09:17:57
Thanks guys, the teeth are on with bolts, so replacing one tooth should be no problem. There is a seal at the base of the pin that drives out when you drive out, the pin and that is also the first thing you are supposed to replace when you remove the pin, as this is the seat for the pin when replacing it. There doesn't seem to be much room below the pin either, because it is protected with a steel shield that is not removable.I haven't tried to do this yet so it just maybe like everyone says, not a big deal, I just may be complaining about nothing....thanks again for all your comments......
