TractorLinks.com
Re: IH 990 SICKLE BAR
IaGary
02-20-2013 04:35:57
I never sharpen the sections.
I replace the bad ones rather than sharpen.
I also bought a whole new sickle about every 600 acres or so.It might be good for you to start with a sickle with bolt on sections.
Bolt on sections can be replaced while the sickle is still on the mower without to much trouble. I also replaced the rivoted sections while on the mower with a rivoting tool.Sometimes it involed removing a guard to do so.
Gary
rrlund
02-20-2013 07:39:09
 Re: IH 990 SICKLE BAR in reply to IaGary, 02-20-2013 04:35:57
Same here. Serrated sections. I replace the sections and guards every other year,the whole bar 4-6 years.
Phil H
02-20-2013 09:17:57
 Re: IH 990 SICKLE BAR in reply to rrlund, 02-20-2013 07:39:09
Thanks guys, the teeth are on with bolts, so replacing one tooth should be no problem. There is a seal at the base of the pin that drives out when you drive out, the pin and that is also the first thing you are supposed to replace when you remove the pin, as this is the seat for the pin when replacing it. There doesn't seem to be much room below the pin either, because it is protected with a steel shield that is not removable.I haven't tried to do this yet so it just maybe like everyone says, not a big deal, I just may be complaining about nothing....thanks again for all your comments......
