TractorLinks.com
Re: Need a part for a John Deere Van Brunt Drill
Bob
02-19-2013 14:39:00
You must need a "boot" for a single disc drill?
What is the drill model?
What is the number on the casting?
Hard Iron bearing or ball bearing? (newer than 1961 or older)
Short or long? (drag bars for each disc alternate between short and long)
LH or RH? (side of the boot the disc mounts to)
The drill you have MAY be similar to the model B in the .pdf parts catalog at the link below, from which you cold post a part number (if different from the number on your casting).
Tx Jim
02-20-2013 04:13:31
 Re: Need a part for a John Deere Van Brunt Drill in reply to Bob, 02-19-2013 14:39:00
Ken
Here's a list of boots used on the 8000 series drills. The same boots(part #s) also were used on the earlier rubber tired drills such as the model B,FB,FB-A & FB-B which are the ones I'm familiar with. IIRC the number is cast into the boot. The AF boot & hard iron brgs utilized the same boot. Older iron wheel drills utilized a a different boot for mounting hard iron brgs as the hole was "square"
KK168M SEED BOOT 1 ( Z82M) SHORT OPENER, R.H.
KK169M SEED BOOT 1 ( Z83M) SHORT OPENER, L.H.
BB3098M SEED BOOT 1 ( A634M) LONG OPENER, R.H.
BB3099M SEED BOOT 1 ( A635M) LONG OPENER, L.H.
QQ1264M SEED BOOT 1 ( M61848) SEMI-DEEP, LONG OPENER, R.H.
QQ1265M SEED BOOT 1 ( M61849) SEMI-DEEP, LONG OPENER, L.H.
This post was edited by Tx Jim at 04:29:23 02/20/13 2 times.
Ken Sweet
02-20-2013 07:07:52
 Re: Need a part for a John Deere Van Brunt Drill in reply to Tx Jim, 02-20-2013 04:13:31
The casting # shown in the picture on the left side of the picture is 6B- A634MLR. Need the whole assembly and disc also. Standing behind the drill, this piece is on the left side with single disc opener discs. Thanks Ken Sweet
Tx Jim
02-20-2013 09:11:09
 Re: Need a part for a John Deere Van Brunt Drill in reply to Ken Sweet, 02-20-2013 07:07:52
Ken
Does your drill have LH & RH openers? Some drills had the openers that went only one direction.
Ken Sweet
02-21-2013 09:00:12
 Re: Need a part for a John Deere Van Brunt Drill in reply to Tx Jim, 02-20-2013 09:11:09
The one I need is on the left side standing behind looking forward. Ken Sweet
Tx Jim
02-21-2013 09:47:39
 Re: Need a part for a John Deere Van Brunt Drill in reply to Ken Sweet, 02-21-2013 09:00:12
That should sub to a BB3099M for just the boot
This post was edited by Tx Jim at 09:48:10 02/21/13.
