| Author |
[Modern View]
| 57JD320S Po
02-01-2013 16:20:42
184.34.16.230
I need some help. I recently purchased an IH 200 spreader. It is in good shape and everthing workks as it should. The only problem is that the previous owner started replacing the chain. I have some new chain and tabs, "S" of course, and the bars. I have ordered a manual and an awaiting delivery, but would like to get a head start on parts to make it completely operational. As far as I know it is supposed to have 15 bars, all of which, I have. Can some one advise how many links go between each bar and how many total there are supposed to be. If they could also confirm that it is in fact 15 bars as well. Any and all help will be greatly appreciated.Thanks Forrest |
| Cienna
02-02-2013 07:50:54
75.88.64.60
Re: IH McCormick Model 200 Manure Spreader in reply to 57JD320S Po, 02-01-2013 16:20:42
|  Forrest---Checked my spreader to make sure---There are 13 slats on a Mod 200 spreader---and there are 5 links between the slat links. If you happen to need certain other parts for this spreader, I might have what you are looking for. Martin |
| Bret4207
02-03-2013 12:09:58
64.19.90.196
Re: IH McCormick Model 200 Manure Spreader in reply to Cienna, 02-02-2013 07:50:54
| Wow Cienna! That's a gorgeous spreader. IMO the McD/IHC 200 was the best shredding spreader ever made. Mine is down for anpron chain change right now. Great spreader and yours is a thing of beauty! |
| 57JD320S Po
02-03-2013 16:18:56
184.34.8.216
Re: IH McCormick Model 200 Manure Spreader in reply to Bret4207, 02-03-2013 12:09:58
| Since you are changing apron chain as well, can you confirm number of bars and links between bars? |
| Bret4207
02-04-2013 04:15:48
64.19.90.196
Re: IH McCormick Model 200 Manure Spreader in reply to 57JD320S Po, 02-03-2013 16:18:56
| Afraid not. I'm switching mine to 67H. The "S" chain disappeared many years ago off mine. |
| Cienna
02-04-2013 05:35:07
75.88.64.60
Re: IH McCormick Model 200 Manure Spreader in reply to Bret4207, 02-04-2013 04:15:48
| BRET----If you change the chain to #67, you"ll have to change the sprockets as well. #67 chain WILL NOT work on "S" sprockets without damage being done. |
| Bret4207
02-05-2013 15:57:39
64.19.90.196
Re: IH McCormick Model 200 Manure Spreader in reply to Cienna, 02-04-2013 05:35:07
| Yeah, I know. The changing the sprocket part is why it's taking so long. The idlers on the front are easy. The 2 drive sprockets are the hard part.
This post was edited by Bret4207 at 15:58:35 02/05/13. |
| Dave - MI
02-20-2013 19:55:49
64.112.219.111
Re: IH McCormick Model 200 Manure Spreader in reply to Bret4207, 02-05-2013 15:57:39
| | Bret - I"ve been trying to get my old spreader working again. It still has the "S" chain but needs an idler sprocket. Could you or anyone else contact me if there is an old one available? Thx DAVE |
| Dave - MI
02-23-2013 05:46:21
64.112.200.144
Re: IH McCormick Model 200 Manure Spreader in reply to Dave - MI, 02-20-2013 19:55:49
| Many Thanx, I wasn't sure where to find this type of sprocket (for "S" chain) since I've been told by my local IH -Case shop that something this old is off the books and not available. |
| Bret4207
02-21-2013 04:47:38
64.19.90.196
| Valu- bilt used to list entire "S" apron chains. They may have the idlers too.
This might help= http://www.ytmag.com/cgi-bin/viewit.cgi?bd=implment&th=68582%3E |
| Larry-Tx
02-01-2013 18:22:10
67.22.209.207
| I have a IH 100 spreader and their are 5 links between the crossbars in the floorchain. My chain has 9 crossbars being a smaller spreader. |
