| Implement Alley Discussion Forum |
Topic: Re: New Holland Bale Wagon
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Case Nutty 1660
01-31-2013 15:56:37
75.127.24.27
Mel gave good advise, I will add that one of the most important things is to have a tight equal sized bale, I liked a 42" long bale as they would make a very good three wide stack, I had a 1002 I leased several years that worked well it was just to small for me, I then bought a 1034 and run it for 10 years and I loved it, one thing a 1034 has that a 1033 does not is a hyd returned 3rd table rack, you must hold the 3rd table lever until it returns to the forward position each time you unload, I liked this better as the 1033 has a spring return rack that does require some maintance, not bad but it does wear out the brake shoes every few years depending on how much you use it, other than the chute chain and the pump drive chain there is not much that wears out I did replace the chute skid shoes once also but that was mostly from the PO who did not adjust the height and it rubbed the ground too much, our hills here was not too bad except going down hill you some times would need to stop the 2nd table until you got more level as it could make it fall, depending on the hill usually I would just lock the table up at the end of its cycle to hold the row inplace then when I got at the bottom release it and all was fine, putting a tier tye in at the 5th row worked best for me and made the stacks very stable, however that is something also very important to stacking the best stack yards I made by gradeing the area to have the outside of the stack rows higher than the middel to make the satck lean towards the center, you can have the stack run uphill with great results also, stacking on a down hill slope takes a bit of practice and is to be avoided if at all posibble, another tip I liked to do was to lay down and stake ribbon to line up the drawbar with on each row this makes learning how to stack much easier, also with a tractor balewagon it is easy to "pack" each stack in tight to the previous one, I liked a 80-100hp tractor on mine mainly for weight when stacking and also I hauled/delivered 200-300 ton to customers 5-10 miles from my field and the 100hp tractor ran upill no problem in road gear with out shifting, hope this helps you a bit, I myself if I still baled any amount of small squares would not be without one they worked tha well for me and I put up 125000 bales a year with mine good luck cnt |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
