TractorLinks.com
Re: listing of old implement make model numbers?
sdmike
01-30-2013 09:51:31
Lewis, when shopping for implements remember that you have a 60hp tractor. Some implements will say what HP they are rated for. Also, if you are going to use your 3 point hitch, remember that a JD 3010 has a Category 2. If you are looking for a JD disk to pull behind that 3010, for example, common models are AW,RW and BW, probably in the 12-14' range.
Congratulations with the 3010. I own 2 4010D's. Raised on 3010D, 4010D's and 4430's. Mike
Tx Jim
01-30-2013 10:34:19
 Re: listing of old implement make model numbers? in reply to sdmike, 01-30-2013 09:51:31
3010/4010 were easily converted to Cat l on the 3pt by using bushings readily available at JD or any farm implement store and flipping the sway blocks 90 degrees.
