Yesterday's Tractor Co.
Shop Now View Cart
Re: Help w/ rough date of Little Wonder single bottom
01-28-2013 16:49:20
The flat bars... were they just like 1/4" x 1" x wheel width and held with one bolt? Also, I too would like to know the color scheme. I have seen them done with variations of the red/white/blue, but what do you think is the correct way to paint it? Thanks!
LA in WI
01-30-2013 11:48:58
 Re: Help w/ rough date of Little Wonder single bottom in reply to rustandgrease, 01-28-2013 16:49:20
It"s been a couple years since I saw the flat bars on the lift wheel, but as I recall they were the width of the wheel and about 1"-1 1/2" wide.
I do not think they were flat, but were bent U-shaped lengthwise so they had the 2 edges sticking up for more traction. But that shape could have been made by the plow owner thru the years....who knows what was done over so many years.
I also have seen a wheel with bolt heads sticking up for traction, with a nut on both sides of the wheel to lock them tight. I think that was an owner design.
I have a #4 on steel, but the left wheel axle is badly bent in; I think it might have been dropped off a truck as something violent had to happen to do that damage. I might take off the moldboard, the 2 handles, the hitch, the coulter, etc. and scrap the rest.
LA in WI
01-30-2013 16:47:51
 Re: Help w/ rough date of Little Wonder single bottom in reply to LA in WI, 01-30-2013 11:48:58
I don't need to make the cleats exact but I'd like to get close to original looking. I have also seen the bolt/nut design somewhere as well. I am sure that would work too. As you can see mine is missing the coulter, so if you or anyone has one complete from the frame clamp down... I'd be interested!
LA in WI
01-28-2013 21:11:57
#4 and #8 IH plows were basically same paint schemes. Hitch and coulter arms are black. Axles, hubs, lifting springs, back of moldboards and lifting mechanism parts are IH blue. Frame and rest of parts are IH red. Wheels are IH white.
IH #2150 red is used nowadays.
IH blue not available, but NAPA has #53-3736A for correct match and other brands can match it also. Ford blue is not the same.
IH 935 White is a cream color, close to same as on hoods of 560, 460, etc.
This site might have what you need and I know that Carter and Grueneveld (sp?) also has paints for plows...see their website; C & G IH dealer.
LA in WI
