IH 800 Cyclo Planter parts help needed
IHMANKY
Can't find it anywhere, and would like to have the one to put in it prior to taking off the old. I have a wheel bearing clicking loudly on the drive wheel of my 800 planter. Pretty sure it barely made it in the shed, hate to move it again without replacing the bearing. I can't find a part number or description anywhere that tells me what the bearing size is. Would like to get one from a bearing supplier close by as it would save me the 70 mile trip to CIH.
I have a 900..not sure if there the same..should be ..mine has a hex stub shaft and hex brgs...had the same noise once and ended up needing a new hub, shaft and bearings..dealer had shaft and brgs in stock. not too bad price wise as I recall..good luck
Messick's shows the 800 plate type, but no 800, 900 or 955 cyclo trailing model. Not sure the plate type had the same setup, don't think it does.
