Woods batwing parts
jdetig1
Anyone know where a good place to buy woods batwing parts? Or how much a center gearbox costs and how much a wing gearbox costs for a woods 3180?
Any Woods dealer can provide that info. You aren't likely to find aftermarket gearboxes that fit like OEM. A local Woods dealer that can place a free-freight stock order will probably beat a cut-rate dealer in a different area code that has to charge you shipping on those heavy items.
I have found Woods parts are nearly impossable to get aftermarket, that said I have found there is a difference 10-20% between dealers. The local JD dealer has the best prices at least last year. A new center gearbox may be a dealbreaker, if it the mixer type.
The center gear case on on of them is going to be plus or minus $2000. The wing box will be $1000 or so.
What is wrong with the ones you have??? IF you are looking at a used one with those pieces bad walk away.
