TractorLinks.com
John Deere plow
Ellis Kinney
01-20-2013 09:57:38
OK, I bought a set of jointers for my plow. Without discussing what a dumb move that was--- could someone please describe for me how to locate them on the beams and how to adjust them for height? Thanks, Ellis Kinney
IHCPloughman
01-21-2013 15:33:30
 Re: John Deere plow in reply to Ellis Kinney, 01-20-2013 09:57:38
Already did:
http://ytforums.ytmag.com/viewtopic.php?p=5697731&highlight=#5697731
If you use Classic View, I can understand not seeing my post.
Ellis Kinney
01-21-2013 14:06:09
Thank you bush hog papa. Just the info I needed. Ellis
Bret4207
01-21-2013 05:11:55
I can;t tell you anything about JD plows, but I can tell you that on a IHC Little Genius, when you get the jointers set right you'll love them! No more green sticking up, and you get that even with a wire of chain. You'll also find that the furrow rolls over more, no more "standing on edge" which is something we get all the time on our heavy clays.
When they work, they work fantastic. Getting them set.......that takes some time and head scratching.
B-maniac
01-20-2013 16:34:27
This is my 4B without jointers. You are right , you don't need them. If you plow tall grass etc, use a log chain and hang from coulter mount area and let dangle back so the plowed ground covers the tail end of it and it will cover anything up to 4-5' cover crops. Neighbor plowed rye taller than his tractor one year and never as much as a sprig of grass showing when done. Really a pretty sight to watch.
BushogPapa
01-21-2013 10:23:53
 Re: John Deere plow in reply to B-maniac, 01-20-2013 16:34:27
Final adjustments must be made with the plow in the ground and at the depth you will be plowing..
Set the Jointer to be just touching the side of the Coulter and about 1"- 2" (average) into the soil..
Anytime you change the adjustment of the Coulter, you need to re-adjust the Jointer too..
Ron..
dboll
01-20-2013 18:35:59
you guy's must have a source of cheap log chains, No.9 wire does the same thing
Ellis Kinney
01-20-2013 12:20:36
Sorry I did not identify my plow. 4B Ellis
Leroy
01-20-2013 10:57:58
Do not remember what your plow is but the Jointers for a cast beam plow (No. 4, No. 52 and like) will not fit on a bar beam type as a No. 44, No. 55, 810, 412, and so on.
