TractorLinks.com
Re: Getting my plow going 3! JD No 44
NDaircapt
01-18-2013 20:54:58
Ive got a partial # on the #2 bottom landslide 79- then it disappears behind the frog. Anybody know the rest? If I do anything, I think #1 landside needs replaced
NDaircapt
01-18-2013 21:18:17
 Re: Getting my plow going 3! JD No 44 in reply to NDaircapt, 01-18-2013 20:54:58
You can see the # 1 landslide the best from the top down picture, its about wore off/cut off even with the back edge of the frog also it curves up towards the rear. Is that landslide supposed to be different than the rear bottom? if its longer will it plug?
BushogPapa
01-19-2013 14:49:05
 Re: Getting my plow going 3! JD No 44 in reply to NDaircapt, 01-18-2013 21:18:17
I like to lengthen the front Landslide on mine...it only will help the rear furrow slice to turn, will not contribute to plugging.. Rear of Landslide should be as thick as the front..Top and Bottom.. You can solidly "Tack" a new piece of 1/4" to 3/8" Steel to the rear half of the existing landslide and it will be fine..I leave it as Long as I think I can..4 to 5" longer on the front Landslide.. More Modern plows often had an optional "Landslide Extensions" that worked exactly the Same.. (AC.).. Ron.
DeltaRed
01-18-2013 22:12:16
Only the rear landslide is long.All the ones in front of the rear are short.Question is,How thick are they?
