Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Getting my plow going 3! JD No 44
[Return to Forum]
ndaircapt
01-18-2013 20:22:31
96.3.182.75
Thanks for all you guys's help over the last week!
Ive learned more about this plow in 72 hours than Ive know in the last 5 years. I took some more pictures close up and hope you can tell me some more information or help date the plow for me. Got the plow in the garage with the 60 - fitting it was no small feat! Soaking all the hardware in "PB Blaster" each day to prepare to take apart if necessary. Also started to shine the front moldboard some. Im still undecided whether to go to the "new" frog and bottom or try to plow with the bottoms I have.
Shares are definately "not sharp" there is about 3/16 of an "edge" Landside on bottom # 1 pretty bad, curved up towards the rear. As you can see in my previous pictures moldboard 1 is broken and welded. #2 landslide pretty good but share in worse shape. did find "JD" cast into both culters but they are different from each other.
"EP 312 EP 314 JD" part # on moldboard. "347 Solid" on the bottom of the share. Is this bottoms right for this plow considering the frame spacing (is it set for 16")? Still alittle confused on this subject.
[Reply]   [No Email]
55 50 Ron
01-19-2013 20:28:15
209.131.224.57
 Re: Getting my plow going 3! JD No 44 in reply to ndaircapt, 01-18-2013 20:22:31
According to Parts Catalog PC158, the 347 share is
a 14 inch.
The EP314 JD on your moldboard is a bit confusing
to figure out from the Parts Catalog. It lists it
as 10, 12, or 14 inch. Maybe you had to specify
which size you wanted when you bought the plow.
The catalog also lists the moldboards as Sod
Bottoms and the shares as Breaker shares for use
with Breaker Bottoms. But the drawings for Sod and Breaker bottoms shows them to very different in shape.
[Reply]  [No Email]
ET
01-20-2013 03:36:34
50.122.164.49
 Re: Getting my plow going 3! JD No 44 in reply to 55 50 Ron, 01-19-2013 20:28:15
I belive that EP312 and EP314 bottoms both used the same moldboard. The diffrents is cut is a diffrent share.
[Reply]  [No Email]
Earl-IL
01-19-2013 10:12:34
50.81.209.158
The EP series of bottoms are very popular in competition plowing. The EP 314-316 moldboards are not being manufacture at this time.White Horse Machine & Equipment Gap Pa. 717-768-8313 ask for David,Henry or Melvin King, has the tooling for the 347 share call them & encourage them to build some shares
[Reply]  [No Email]
raydex 234
01-19-2013 05:20:53
209.62.248.106
I was wondering where you are located. I have a nice set of slat bottom moldboards with the throw away lays that I want to get rid of.
[Reply]  [No Email]
Carlyle Hoffman
01-19-2013 05:50:20
74.71.111.250
 Re: Getting my plow going 3! JD No 44 in reply to raydex 234, 01-19-2013 05:20:53
radex 234,would be interested in you slat btms , 1-607-965-8612 ?????/ anytime.
[Reply]  [No Email]
Greg K
01-19-2013 05:17:15
75.104.160.54
No answers for you but a question. Where did you get the tire ofr the left front at? and what size is it ?
[Reply]  [No Email]
Earl-IL
01-19-2013 10:19:47
50.81.209.158
 Re: Getting my plow going 3! JD No 44 in reply to Greg K, 01-19-2013 05:17:15
Miller Tire in Wauseon, Ohio has that tire. call 1-800-621-1955.
[Reply]  [No Email]
NDaircapt
01-19-2013 05:39:15
96.3.182.75
I bought the plow with the new tires on it. The Left front is a "Galaxy" 6.00-16 6ply Super Tractor R-1.
[Reply]  [No Email]
NDaircapt
01-18-2013 20:54:58
96.3.182.75
Ive got a partial # on the #2 bottom landslide 79- then it disappears behind the frog. Anybody know the rest? If I do anything, I think #1 landside needs replaced
[Reply]  [No Email]
NDaircapt
01-18-2013 21:18:17
96.3.182.75
 Re: Getting my plow going 3! JD No 44 in reply to NDaircapt, 01-18-2013 20:54:58
You can see the # 1 landslide the best from the top down picture, its about wore off/cut off even with the back edge of the frog also it curves up towards the rear. Is that landslide supposed to be different than the rear bottom? if its longer will it plug?
[Reply]  [No Email]
BushogPapa
01-19-2013 14:49:05
173.88.51.117
 Re: Getting my plow going 3! JD No 44 in reply to NDaircapt, 01-18-2013 21:18:17
I like to lengthen the front Landslide on mine...it only will help the rear furrow slice to turn, will not contribute to plugging..
Rear of Landslide should be as thick as the front..Top and Bottom..
You can solidly "Tack" a new piece of 1/4" to 3/8" Steel to the rear half of the existing landslide and it will be fine..I leave it as Long as I think I can..4 to 5" longer on the front Landslide..
More Modern plows often had an optional "Landslide Extensions" that worked exactly the Same.. (AC.)..
Ron.
[Reply]  [No Email]
DeltaRed
01-18-2013 22:12:16
71.208.8.212
Only the rear landslide is long.All the ones in front of the rear are short.Question is,How thick are they?
[Reply]  [No Email]
DeltaRed
01-18-2013 20:30:04
71.208.8.212
I'd say that share is about perfect.Full cut,not too
much overlap.A share does not need to be "sharp",it
needs to have 'suck'.Too sharp/thin it can break if
it hits a rock.By the pic,the share looks to be in
good shape,good 'suck'.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
