Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: bucket loader
old
01-17-2013 12:31:22
What is the hyd system you use. A front crank shaft driven pump of the tractor hyds system?? If the tractor system how is it set up?? Does it run off the pressure check plug or does it have a set of levers?? Hard for use to help you help your self with out more info. If off the pressure test plug then the 3 point arms have to be chained down to get pressure and a very poor set up to say the least
David Zoanetti
01-20-2013 09:58:16
 Re: bucket loader in reply to old, 01-17-2013 12:31:22
The bucket runs off the tractor hydraulic system through a transfer valve on top of the lift cover to a two spool control valve operating the single acting lift arm piston and double acting bucket piston.
old
01-20-2013 10:02:56
 Re: bucket loader in reply to David Zoanetti, 01-20-2013 09:58:16
3 point arms need to be chained down then to work and as I said a poor system at best
Copyright © 1997-2015 Yesterday's Tractor Co.
