Yesterday's Tractor Co.
Shop Now View Cart
Re: Getting my plow going part 2
01-16-2013 18:50:51
Center of draft on that 2btm. plow is between the 1st and 2nd bottom. So your hitch should be set so you pull from the center of the two bottoms. Looks like you are more in line with the second bottom.
01-16-2013 19:02:15
 Re: Getting my plow going part 2 in reply to casecollectorsc, 01-16-2013 18:50:51
I got that out of my previous thread the 17.5" (1 bottom cut plus 1/4 bottom width) from the right facing forward and hitch perpendicular to the crossbar. When I get it home, going to take some pictures with the hitch set and hooked to the tractor to help get plow alignment right. Looking for an operators manual too to help set the plow right. Will have to angle my drawbar as drawbar center to inside of right rear tire in centered position on tractor is 29" (narrow as it goes) on my 60. Also heard about "off hitching" to center the plow. Will cross that bridge when I get to it. Gotta prepare the plow first.
01-16-2013 19:28:17
 Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 19:02:15
I should clarify, I now know the hitch is set wrong and should be set more like as described above.
