TractorLinks.com
Re: Getting my plow going part 2
BushogPapa
01-16-2013 17:50:03
Sometimes it is hard to tell just how much "suck" is left in a used set of Shares..
I like to make new Landslides and leave them about 5" longer than the original on the Front and as long as is room on the rear bottom.. Helps make the slice turn over better and keeps the plow from crowding to the Left in damper ground..(keeps the furrow straighter)..
Ron..
NDaircapt
01-16-2013 17:56:09
 Re: Getting my plow going part 2 in reply to BushogPapa, 01-16-2013 17:50:03
Do you have a part # for the shares I might need? I havent looked too much "down low" to see what shape my bolts are in. Will look closer when I get it in the shop this weekend.
BushogPapa
01-16-2013 18:19:28
 Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 17:56:09
No numbers, here..but your shares appear OK..but a picture can be deceiving..some shares were designed to have a greater amount of Suck than others... I have seen a JD 2 Bottom plow go from "going in good", to "won't go in at all" in just a couple of rounds.. Could be the conditions were getting Dryer maybe it was the shares. Some just change over to "High Speed Bottoms", so they can use "Throw-Away" shares..that are much cheaper and easier to find..
Ron..
NDaircapt
01-16-2013 18:29:34
 Re: Getting my plow going part 2 in reply to BushogPapa, 01-16-2013 18:19:28
Good to know.... I read somewhere that high speed bottoms takes a whole different frog?
BushogPapa
01-17-2013 20:30:30
 Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 18:29:34
Yes. Usually, you would purchase a decent used downer plow, for parts..
Ron..
