Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Getting my plow going part 2
[Return to Forum]
ndaircapt
01-16-2013 16:47:43
96.3.182.75
Hi guys,
Heres some pictures of my plow I pulled out of the snowbank today. I started the thread last week on scouring plow bottoms.
Its a John Deere 44. It says "No. 16 Frame" on the front. Its clutch lift.
What do you think of my shares and landsides? will they work? I know the hitch is set wrong, will get back to that.
Will it scour?
[Reply]   [No Email]
Mike Aylward
01-18-2013 13:51:31
216.145.134.145
Re: Getting my plow going part 2 in reply to ndaircapt, 01-16-2013 16:47:43
Unless you want the plow to be 100% original, when you need shares or other wear parts that would be a good time to convert it to HS bottoms. Get the whole bottom assembly (share, moldboard, shin, frog, etc.) and it will bolt right on your standards with two bolts. Parts will be much easier to find and the plow will also pull easier. With your frame you could use 14" or 16" bottoms by switching the standards front to back. Offset in is 14", offset out is 16". Pretty simple. Mike
  [Reply]  [No Email]
Leroy
01-17-2013 11:11:22
69.88.205.38
You have plenty of share, they just need to behammered out to sharpen by a good blacksmith, DO NOT gring on them because if you do they will be junk. They have enough nose that they do not need any thing welded on, wil only hurt with the shape they are in. Better health and I could sharpen them. The frame sayling 16 means it is a large frame and could be furnished with either 14" and have the beams set for 14" or 16" furrow or 16" bottoms set for 16" furrows, some also would take that 16" bottom and set to cut 14" thinking they would get a better turn over. Can't see that part to tell is set for 14 or 16" furrow. The tire just go to a tire place and find one that sells the tires for the boat trailers or foldup campers and get one that is too smooth for the highway and it will be perfect on that plow, fact is the size you give says that is what is on now. The orignal was a 3:50 x 12" tapered tread but if you can find that you are talking the price of the plow. The operators manual will tell you how to sharpen those shares. The angle of those moldboard extensions tell me that it is set up to plow shallow 6" to not over 7" if that is a 16" bottom and normal depth for a 16" bottom is figured at 1/2 the width for depth so that is 8", for that deep those extensions would want to keep the plow from going that deep so just loosen the bolts and slide it to angle that it just finnishes rolling the furrow over.
  [Reply]  [No Email]
TomA
01-17-2013 00:37:11
76.9.72.88
It is hard to tell from those pics but I dont see much suck to
those shares. I weld a chunk of springtooth or leaf spring on
the points to re point them. Clean the moldboards the best
you can, coat them with graphite paint. It will scour right
now. When it wears off the moldboards will be shined up.
Barnyard tech.
  [Reply]  [No Email]
casecollectorsc
01-16-2013 18:50:51
75.102.174.227
Center of draft on that 2btm. plow is between the 1st and 2nd bottom. So your hitch should be set so you pull from the center of the two bottoms. Looks like you are more in line with the second bottom.
  [Reply]  [No Email]
NDaircapt
01-16-2013 19:02:15
96.3.182.75
Re: Getting my plow going part 2 in reply to casecollectorsc, 01-16-2013 18:50:51
I got that out of my previous thread the 17.5" (1 bottom cut plus 1/4 bottom width) from the right facing forward and hitch perpendicular to the crossbar. When I get it home, going to take some pictures with the hitch set and hooked to the tractor to help get plow alignment right. Looking for an operators manual too to help set the plow right. Will have to angle my drawbar as drawbar center to inside of right rear tire in centered position on tractor is 29" (narrow as it goes) on my 60. Also heard about "off hitching" to center the plow. Will cross that bridge when I get to it. Gotta prepare the plow first.
  [Reply]  [No Email]
NDaircapt
01-16-2013 19:28:17
96.3.182.75
Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 19:02:15
I should clarify, I now know the hitch is set wrong and should be set more like as described above.
  [Reply]  [No Email]
Greg K
01-16-2013 18:34:49
75.107.96.58
Where do you find the tires for that plow?
  [Reply]  [No Email]
NDaircapt
01-16-2013 18:38:55
96.3.182.75
Re: Getting my plow going part 2 in reply to Greg K, 01-16-2013 18:34:49
I bought the plow about 5 years ago from a guy and they were on it already. dont know why he "gave up" on this particular plow. paid $225 for it as-is. Now I just need to make it work. Ill look at the tires closer and see if there is a manufacturers stamp on them when I get it home tommorrow.
  [Reply]  [No Email]
Brian Dan
01-16-2013 18:32:15
50.76.251.129
Wate till spring and find an old gravel pit.
plow a couple hundred feet and your plow will be clean. My dad did that all the time back in the day.
  [Reply]  [No Email]
NDaircapt
01-16-2013 18:36:04
96.3.182.75
Re: Getting my plow going part 2 in reply to Brian Dan, 01-16-2013 18:32:15
Id try that but no gravel nearby :-( have to do it the hard way. got some decent sand in my soil though.
  [Reply]  [No Email]
BushogPapa
01-16-2013 17:43:48
173.88.51.117
I have GIVEN these Instructions several times and NOT ONE of you have paid any attention....
Get that 4" (or 4 1/2") Angle Grinder out (AND a good dust Mask)...
Get some of the Thin "Cut-Off wheels"..you will need about 2 for each plow bottom...
HOLD the Cut-off wheel at a low angle..about 30 degrees to the steel surface..
It WILL NOT gouge or even Scratch the steel surface, but will remove the Rust right down to the Black Oxide Under the Rust (and THAT WILL scour nicely)...
NOW, you could go back over with a "Flapper Wheel, but you really will NOT need to..
NOW..IF you Listened, you will save many hours of Work and BE Ready to Plow...
TRY IT...
"NUFF Said..
Ron..
  [Reply]  [No Email]
NDaircapt
01-16-2013 17:51:53
96.3.182.75
Re: Getting my plow going part 2 in reply to BushogPapa, 01-16-2013 17:43:48
There will be a "pre-scour" cleaning done this winter using combinations of the techniques I got from this post and from the thread a week ago. Thanks Bushhog P.
  [Reply]  [No Email]
RayP(MI)
01-16-2013 17:35:02
207.241.137.116
Shares and landsides look good should last you a long time only doing a few acres. Spent a lot of time pulling one of those around the fields around here - only ours had a hydraulic lift. Properly adjusted, they were a fine plow.
  [Reply]  [No Email]
ndaircapt
01-16-2013 16:53:41
96.3.182.75
My questions are:
1. where can I get a reproduction or original operators manual for it besides Deere? any good websites?
2. Do you see any parts missing?
3. Do you think the shares are sufficient to plow 2-3 acres a year? If I get new shares, what am I looking for?
4. See any reason this plow wont work?
5. The tailwheel is a 4.80 - 12. Is it going to be tough to get one? Its flat. How does it come off?
6. Any way of telling what year it is? couldnt find a stamp anywhere yet
  [Reply]  [No Email]
Tyler-MO
01-17-2013 06:50:45
50.40.174.43
Re: Getting my plow going part 2 in reply to ndaircapt, 01-16-2013 16:53:41
My questions are:
websites?
I have good copies (had some made awhile back) for
$15.
The front coulter is what looks like an IHC or
P&O; not an original JD (not that it matters from
a standpoint of using the plow).
looking for?
You've got EP (Sod) plow bottoms. Those shares are
going to be more difficult and more expensive to
purchase compared to regular General Purpose (NGP)
bottoms.
Aside from adjustment, I can't see why it wouldn't
work. The shares don't look like they are perfect,
but not completely worn out.
The tail wheel would be a 4.00x12 implement tread
tire. Carsyle makes one that is still American
made.
There are not serial number stampings on these
plow. Only a forensic exploration with a part
catalog might yield a rang of years which it could
have been built, but it's very doubtul you'll ever
get it down to an exact year of production.
Tyler in IL
  [Reply]  [No Email]
Plowman
01-16-2013 18:57:02
216.201.49.122
I have lots of different plows manuals for sale for plows. Call Steve 419-618-0017 Thanks Plowman
  [Reply]  [No Email]
BushogPapa
01-16-2013 17:50:03
173.88.51.117
Sometimes it is hard to tell just how much "suck" is left in a used set of Shares..
I like to make new Landslides and leave them about 5" longer than the original on the Front and as long as is room on the rear bottom..
Helps make the slice turn over better and keeps the plow from crowding to the Left in damper ground..(keeps the furrow straighter)..
Ron..
  [Reply]  [No Email]
NDaircapt
01-16-2013 17:56:09
96.3.182.75
Re: Getting my plow going part 2 in reply to BushogPapa, 01-16-2013 17:50:03
Do you have a part # for the shares I might need? I havent looked too much "down low" to see what shape my bolts are in. Will look closer when I get it in the shop this weekend.
  [Reply]  [No Email]
BushogPapa
01-16-2013 18:19:28
173.88.51.117
Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 17:56:09
No numbers, here..but your shares appear OK..but a picture can be deceiving..some shares were designed to have a greater amount of Suck than others...
I have seen a JD 2 Bottom plow go from "going in good", to "won't go in at all" in just a couple of rounds..
Could be the conditions were getting Dryer maybe it was the shares.
Some just change over to "High Speed Bottoms", so they can use "Throw-Away" shares..that are much cheaper and easier to find..
Ron..
  [Reply]  [No Email]
NDaircapt
01-16-2013 18:29:34
96.3.182.75
Re: Getting my plow going part 2 in reply to BushogPapa, 01-16-2013 18:19:28
Good to know.... I read somewhere that high speed bottoms takes a whole different frog?
  [Reply]  [No Email]
BushogPapa
01-17-2013 20:30:30
173.88.51.117
Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 18:29:34
Yes.
Usually, you would purchase a decent used downer plow, for parts..
Ron..
  [Reply]  [No Email]
super99
01-16-2013 17:09:47
74.32.242.52
The tire is the same as a small trailer tire, it will work for what you want to do.
Do you have a 4" hand grinder? I use a flap disc wheel on mine to clean the rust off,(wear a dust mask!!!) get it as shiny as you can, and then grease or paint the shares and bottoms to keep them from rusting. Soak all moving parts excessively until they free up. Chris
  [Reply]  [No Email]
NDaircapt
01-16-2013 18:33:42
96.3.182.75
Re: Getting my plow going part 2 in reply to super99, 01-16-2013 17:09:47
Thats what appears to be on it right now is a "trailer tire" 4.80 - 12 an Armstrong? Is that tubeless? Does those four bolts just come out and to get off the hub?
  [Reply]  [No Email]
NDaircapt
01-16-2013 17:44:04
96.3.182.75
I have some PB blaster I really like I am going to take after all the fastners once I get it in the shop in case I need to take something apart. planning on "pre scouring" the moldboards too before I try it this spring. trying to prevent a repeat of the dismal try from 3 years ago, hitch miss adjusted, didnt scour, tailwheel trying to jump out of the furrow to the unplowed side.....
  [Reply]  [No Email]
ndaircapt
01-16-2013 16:53:10
96.3.182.75
How do you tell the difference between a 44 A and 44 B?
This post was edited by ndaircapt at 16:57:10 01/16/13 2 times.
  [Reply]  [No Email]
CHUCK CAMBIS
01-16-2013 19:16:47
71.128.198.216
Re: Getting my plow going part 2 in reply to ndaircapt, 01-16-2013 16:53:10
JD NO. 44 Plow manual OM-A1-1048 Plow is listed as
only four types. 44. 44H, 44A, 44AH. The H stands
for hydraulic lift. The 44 has fixed tailwheel and
transports on front two wheels. 44A has pivoting
tailwheel and transports on all three. The drawbars
of the two types will have differences. Bought my
manual on ebay $25 original and very good condition.
  [Reply]  [No Email]
NDaircapt
01-16-2013 19:22:06
96.3.182.75
Re: Getting my plow going part 2 in reply to CHUCK CAMBIS, 01-16-2013 19:16:47
I believe mine a straight 44 then. my tailwheel does not pivot, but must be missing something on my drawbar or out of place to "carry" the rear when raised. a spring?
  [Reply]  [No Email]
willie in mn
01-16-2013 23:47:16
67.142.168.24
Re: Getting my plow going part 2 in reply to NDaircapt, 01-16-2013 19:22:06
That 3/4 or 1 in rod about 3 ft long that is holding the hitch up in the pic is what carries the rear of the plow. The way it sits in the pic, adjust that rod to hold front of hitch 6 in or so higher than the tractor drawbar. Use that as a starting point, adjust as needed after you get the plow in the ground. When in the ground the tailwheel carries the load, there should be some slack in that rod on the hitch.
Hooking up to tractor involves pushing down on hitch with your knee, lifting the tailwheel. It has been over 50 years since Dad died & I left the farm, but IIRC, in transport position the tailwheel rides a foot or so above the ground.
Willie
  [Reply]  [No Email]
NDaircapt
01-17-2013 04:53:59
96.3.182.75
Re: Getting my plow going part 2 in reply to willie in mn, 01-16-2013 23:47:16
Good to know! Thanks!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
