TractorLinks.com
Re: JD 810 3/16 plow
Carlyle Hoffman
01-11-2013 04:14:58
Its called a ROLLING LAND SIDE. Tends to steer the rear of the plow, also effects DEPTH and LATERAL sway.Nearly every mounted plow was provided one, with a few exceptions.
AJB-830
01-11-2013 07:19:00
 Re: JD 810 3/16 plow in reply to Carlyle Hoffman, 01-11-2013 04:14:58
Every JD 810 or similar plow I have seen had a tail wheel. I would suspect someone removed it. Don't think it would be hard to find a tail wheel for it. Possibly someone converted a 4 bottom to a 3 bottom and didn't move the wheel. I converted mine from 4-14 to 3-14. But you could try using it without it. Al
BushogPapa
01-11-2013 10:10:09
 Re: JD 810 3/16 plow in reply to AJB-830, 01-11-2013 07:19:00
Without the tail wheel, you will need to extend the rear Landslide and add an adjustable "HEEL".
Using a Gauge Wheel could control depth fairly well, but you need the extended Landslide, if you do not get the rear wheel assembly..
Ron.
